DIAdem Idea Exchange
Andrea_Perin
Analysis function to generate an index channel out of an existing channel
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
Hi all,
sometimes it can be an advantage for data manipulation to have the possibility to access to an index channel (a channel just containing the values from 1 to n) generated out of channel with length n.
Such a channel would be helpful when using event search function which have to be performed on a certain number of values o in a certain block of data in a channel.
This function could be integrated in the current function "Generate Numeric Channel".
Best regards
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
