DIAdem Idea Exchange
Jane_*_
Axes Labeling with text / textchannels / assignment channel instead of numbers in Report
Status: New
I have not found a straight forward way to label axes ticks with text instead of numbers, so I would suggest this as a feature in a new release. At the moment we are working with text fields which is a very cumbersome way and not very user-friendly when editing the report.
It would be very nice, if there would be a way to implement text labeling for x, y and z axis.
Example: I have a state channel that contains values between 2 and 8. This channel is an assignment channel, therefore I could create a corresponding text channel containing the status description for each value. This way, it would be possible to display a table but as the channel has 3600 values, this wouldn't be very readable and a 2D plot of the state events would be more helpful (e.g. state changing from off to passive etc.)
One could for example expand the axis scaling settings where a tick channel can already be assigned by a text + index or an assignment channel assignment.
Today I found a way of combining a bar plot and a line plot to achieve this goal, which still isn't a nice way:
- Bar plot:  X channel is a numerical channel only containing NoValues [Nv,Nv,Nv,Nv,Nv,Nv,Nv,Nv] (we don't want to see bars), Y channel is a string channel which contains the Y-Axis labeling we want [ -,off,-,on,-,passive,-,idle] (we want our labels on Y-Index 2,4,6,8 - that's why the string channel has "empty values")
- Line plot: X channel is the time channel, Y channel is the state channel, containing values of the set (2,4,6,8)
