DIAdem Idea Exchange
Artemis125
Clear Data Portal
Status: Completed
Hi Artemis and Sadie,
DIAdem 2017 ships with a customizable icon bar for the Data Portal, plus standard "Delete INternal Data" and "Save TDM File As" icons which you can use to delete or save data sets from whatever DIAdem panel you happen to be in at that moment.  Thanks for the great suggestion!
Brad Turpin
DIAdem Product Support Engineer
It'd be nice to be able to clear the data portal without having to go to the NAVIGATION area each time. Adding the ability to clear the data Portal from any screen, especially when scripting, would be much more convenient.
Sadie
3 Comments
Brad_Turpin
Trusted Enthusiast
Hey Sadie,
You can right-click on the top-most icon in the Data Portal tree view (looks like a cylinder) and select the context menu "Delete".
Is that enough, or do you want a button somewhere?
Brad Turpin
Artemis125
Brad,
The delete function does not allow you to save changes made to the data. It does clear it however if you wanted to save changes you'd have to go back to the navigator menu. I know this is a picky thing, just thought i'd put the idea out there.
Sadie
Brad_Turpin
Trusted Enthusiast
Status changed to: Completed
Brad Turpin
