Most of the time it is not clear, which hint should be displayed, if the command is not completely defined. We support the hints with code completion and if you move the mouse over a command. Displaying hints at any time is not planed.
Greetings
Walter
Dears,
I want to propose a check button in settings which would say something like "Automatic CodeCompletion". If you check that, you will see the hint from CodeCompletion anytime you write code not only when you write and hit ctrl + spacebar.
Thank you for your suggestion.
Greetings
Walter
