DIAdem Idea Exchange
JoshRew
Copy VIEW Sheet
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
In DIAdem 2011 we now have the ability to conveniently Copy REPORT sheets and Append VIEW sheets, now it'd be great if we could Copy VIEW sheets (with script accessibility, of course).
I know this has been mentioned before, but doesn't have an "Idea Post" so thought I'd add it so it doesn't get lost.
-Josh
5 Comments
Brad_Turpin
Trusted Enthusiast
Hi Joshua,
I heartily agree, in fact this is one of the features I would personally most like to see added to DIAdem.  I'm confident this will happen, but I fear it won't happen quite as quickly as we'd both like.
Brad Turpin
DIAdem Product Support Engineer
LudekS
The solution is probably not clean (brutal), but works
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim ActiveSheetIndex
Dim i
Dim n,n1,n2
i=0
ActiveSheetIndex = View.Activesheet.Index
n = View.Sheets.Count
Call View.SaveLayout("c:\YourPath\Copy.TDV")
Call View.appendLayout("c😕YourPath\Copy.TDV")
n1=n+1
n2=n*2
For i=n2 to n1 step -1
if not( i=ActiveSheetIndex+n) then
Call View.Sheets.Remove(i)
end if
Next
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
ATarman
This would be a very helpful feature [duplicate VIEW tab].
The script from LudekS works well, but unfortunately, I've had issues with it causing a corruption of the TDV file [I believe this is root cause] if I close DIAdem and reopen the TDV file.
davidwatagis
Hello all
Has there been a DIAdem release since 18-05-2018 with that great idea?
