DIAdem Idea Exchange
Pesmith8
DIAdem 2020 and Python scripting, How best to use VirtualEnv
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
Python Virtual environments allow better control of the dependency versions by project, that I find required. Mostly this is so that the dependencies/package versions are the same between the code as developed, and the code as used by users.
Would like NI to consider adjustments to the current python system so that it can use a virtual Environment. Some to consider, Venv. pyenv, VirtualEnv, PipEnv.
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
