DIAdem Idea Exchange
Radek_Codr
SCRIPT Calling simplification
Status: Completed
From DIAdem 2015 on it is possible to use the channel object as parameter. Example:
ChnSmooth(oMyChannel, oMyChannel, 10, “maxNumber“)
Greetings
Walter
Let argument in object.GetReference(argument) method should be optional and as default set ExtendChnName
  In this case calling of function should look like Call ChnSmooth(oMyChannel.GetReference,oMyChannel.GetReference,10,“maxNumber“)
Also include in Channel object even required properties (description, unit, max, min, length, etc.). This should be equivalent to oMyChannel.Properties(NameOrIndex).Value
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Completed
Greetings
Walter
