Simplify how to create a DataPlugin. I should be able to define a binary layout like a telemetry stream and directly assign channels.
For example, A new GUI would be created. I define the telemetry stream which has three floating point numbers then an integer, repeat. Assign channel names Volts, Amps, Power Out, and Setting. Perhaps set the built-in properties. Press a button the plug in is automatically created.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions and the fact that just a few sponsors are supporting it, we gave this request a low priority.
Greetings
Walter
