DIAdem Idea Exchange
hongcc1
Support SI Notation Format When Export LabVIEW Graph to DIAdem
Status: New
In the current DIAdem version (2024), when the display format of the LabVIEW graph axis is configured to "SI Notation", the data will be interpreted wrongly when export them to DIAdem report. For example, the x-axis of the following graph is set to "SI Notation":
When exporting to DIAdem, the graph is plotted incorrectly:
If look at the raw data (compare to Export Data to Excel feature):
Because DIAdem ignores the pico and nano scale, the first 12 points in pico scaling are appeared larger than the rest of points in nano scale.
This feature should be very important because there will be more Instrument Studio measurement plugins UI are developed in LabVIEW. "Export Data to DIAdem" is a good use case of connecting workflow from Instrument Studio to DIAdem.
