DIAdem Idea Exchange
cfoe
Time Format precision in DIAdem
Status: Completed
Hi cfoe, et al.,
DIAdem 2018 finally ships with the option to expand the precision of time channels to better than 1 msec (in our century).  For backwards compatibility we left that option turned off by default.  Go into the DIAdem settings dialog, then under "General" check the "High resolution for absolute time values" checkbox.  If you then save your *.DDD file, this setting change will persist each time thereafter that you restart DIAdem.
Brad Turpin
DIAdem Product Support Engineer
I checked the DIAdem hepl and saw that the time value converted in text only allows 4 digits for the fraction of a second.
But how can you display datetime in text for more precise values.
For example, if i acquire on a real time target, analog inputs data at 1MHz, all samples are more precisely time stamped than the best text value that you can display.
It would be very convenient to display time stamp like that : 06/19/2013 15:37:50.12345678
instead of that : 06/19/2013 15:37:50.0005
Thanks  !
Best Regards
CFOE
5 Comments
cfoe
Just to correct the previous exemple, you should understand that :
instead of that : 06/19/2013 15:37:50.1234
SmileBoB
Yeah !! It will be awesome !!! Especially when working with high Sample frequency  data !!
cfoe
More precision after a long time with the NI hotline.
DateTime values are defined as a double value.
It means that for a precision higher than the hundred microsecond, the precision is not possible using absolute time due to the less of precision coding it a double.
Languages like .NET can have more precise TimeStamp because DateTime are coded as ticks with a precision of a hundred nanosecond (long values).
The problem using DIAdem is that long values (interger 64 bits) are not supported by DIAdem.
If you want to have precise time, you have to use relative time.
It would be nice for NI and DIAdem to add the DataType I64 in order to improve the DateTime precision.
Best Regards
CFOE
dietfons
NI Employee (retired)
Brad_Turpin
Trusted Enthusiast
Status changed to: Completed
Hi cfoe, et al.,
Brad Turpin
