Hey everyone,
There should be an integrated feature in DIAdem to create Boxplots. You can already find the min Q1 median Q3 and max in the analysis portion. I have not been able to find a good way to make a boxplot in DIAdem, and it's a very clunky process in excell. I've had to use DIAdem to process data then export the interested channels to excel to make acutal boxplots, which still requires a lot of manipulation.
To do this in excel you create a modified boxplot based on the difference in the five number summary. These numbers are put into a stacked boxplot, then the settings are played with to give the finalized look of a box plot.
The Differences plotted as a stacked bar plot looks like the following with borders on and the bottom and top sections made invisible with error bars to mark the min and max values
There should be a way to do a similar process, or even an automatic box plot creator in DIAdem.
Let me know what you think,
Sadie
This request was implemented in DIAdem 2019.
Greetings
Walter
