DIAdem Idea Exchange
nimic
"add or replace" for data objects
Status: Declined
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
Hello
When developing scripts, I frequently add channel groups for analysis results, using
call data.root.channelgroups.add("analysis")
However, when re-running the scripts, successive groups "analysis1", "analysis2" etc. are created. This is a handy feature that I should not want to miss at some times, BUT
at other times I want to skip the creation of new channel groups. As a work-around I litter my code with 'exist'-statements such as
If not call data.root.channelgroups.exists("analysis") then
end if
Set oResGrp = data.root.channelgroups("analysis")
Now, my suggestion is to add a command such as "AddOrReplace" or "Use", which would use the existing group if it exists and creates a new group if not. Pretty much the same behaviour as with the calculator, where
CH("NewChannel")= CH("oldChannel") will create a new channel or overwrite an existing one.
So
would work as we know it and
call data.root.channelgroups.Use("analysis")
would create a new object or use the existing one.
Alternatively one could supply an optional paramter to the .Add-method like
call data.root.channelgroups.add("analysis",0)
 as default using the well-known behaviour whereas
call data.root.channelgroups.add("analysis",1)
would change to create or replace.
Obviously the same would come in handy for channels or other objects that use an .add-method.
Thank you
Michael
2 Comments
Brad_Turpin
Trusted Enthusiast
Hi Michael,
I would find that handy also.
Thanks for the suggestion,
Brad Turpin
DIAdem Product Support
Walter_Rick
NI Employee (retired)
Status changed to: Declined
Hello
Greetings
Walter
