FIRST Robotics Competition Blog
Community Browser
robo_Jeff
0 Comments
Did you know that there are a bunch of built-in FRC examples right in LabVIEW? There are!
Just click on the Help drop-down menu and choose Find Examples. Shablam!  LabVIEW Example Finder!  You'll see an FRC Robotics folder and a roboRIO folder inside it. There, you'll find examples for everything from CAN and Pneumatics to Joystick, Sensors, and Vision.
These examples are ready to run!  You can also customize them, change them, and use them however you want. You can combine them, copy/paste parts of them into other VIs or into your robot project, or just run them independently. The world is your VI!
Have fun!
muffin.vi
0 Comments
Sometimes during the competition, it would be nice if the sensitivity of the joystick could be lowered temporarily to allow you to maneuver more precisely. The code snippet below does exactly that. If you press button #7 on your gamepad (this is the right trigger on my gamepad), it halves the sensitivity of the joystick. That way, you can drop the sensitivity mid-match by simply holding down the right button.
Replace the joystick and motor code in Telop.vi with the snippet below.
The code is quite simple: the Joystick Get Values function outputs both an array of joystick data and an array of boolean button data. The index array function is used to get the boolean value of the specified button, in this case, button #7. That value is fed into a case structure. If the button is pressed, the case structure gives a value of 2. If it is not pressed, it gives a value of 1. The value of the joystick position is then divided by the output. This way, when button #7 is pressed, every joystick value is divided by two, dropping the sensitivity. If button #7 is not pressed, the joystick sensitivity is unchanged and the robot moves at full speed.
tcap
0 Comments
This snippet shows how to read variables from your roboRIO and display them on your custom Dashboard.  It reads the current X, Y, and Z values of the built-in accelerometer and writes them to the SmartDashboard.  The SmartDashboard entries are then read in the PC Dashboard and displayed on a Waveform Chart.
For more information, check out the tutorial from 2014;
https://decibel.ni.com/content/docs/DOC-26296
Begin VI
Place this snippet in the Begin.vi
Teleop VI
Place this snippet in the Teleop.vi
Finish VI
Place this snippet in Close Refs, save data, etc. frame of the Finish.vi
FRC PC Dashboard VI
Place this snippet within the True case of Loop 1.
FRC PC Dashboard VI Front Panel
Gloorious_Leader
0 Comments
This example shows how tank drive works using a gamepad as a controller. Tank drive allows the driver to control the left and right motors independently of each other. Since each side needs to be controlled separately, one must use two inputs/joysticks to control it. A gamepad is a good choice as it has two joysticks on a single device.
Some gamepads have the ability to disable analog mode, which sets the secondary joystick to read as a button rather than a pair of axes. Be sure that analog mode is enabled when using tank drive.
The code below works by opening a reference to each motor and to the gamepad. In this code the motors are controlled by CAN controllers, but it can be easily modified for another controller type. Because the gamepad has both joysticks on it, only one joystick reference is necessary. The axis position of each stick can be fetched using the JoystickGetValues.vi. The Axes output returns the values of the desired axes (in this case Axis 1 and Axis 3). These values can then be applied to the motors after negating one side since the motor(s) should have an opposite orientation.
This Training Module discusses the basic concepts of motor control. These same concepts are applied in the code below.
netsirk
0 Comments
This example explains how to use an encoder to determine the direction and rate of a motor controlled by your roboRIO. Encoder functions can be found in the Encoder subpalette, within the Sensors subpalette of the WPI Robotics Library palette on the block diagram.
These functions work specifically for a quadrature encoder, which contains two rotating disks A and B. Digital pulse outputs from A and B translate into speed, depending on the frequency of pulses, and direction, depending on the which disk’s pulse is detected first.
Connect your quadrature encoder to the DIO pins on the roboRIO such that encoder outputs A and B represent two separate DIO lines. Refer to the diagram shown on the front panel of the MotorwithEncoder.vi example for further direction. (Help > Find Examples > FRC Robotics > roboRIO > Robot and Motor)
How to include in 2015 Robot Project:
Begin VI
The WPI_EncoderOpen.vi automatically creates an encoder reference from two DIO inputs. (LabVIEW will generate two WPI_DigitalInputOpen.vi’s and convert these to source inputs for this VI). This reference can be passed to WPI_EncoderConfigureTimer.vi, which allows for further configuration of the encoder with inputs that specify the number of pulses to average for rpm calculations, as well as the minimum pulse rate before the encoder is considered stopped.
Robot Main VI
The WPI_EncoderGet.vi is used to return information from the encoder about count, direction, and period of pulses, or if the encoder is stopped. Additionally, the WPI_EncoderReset.vi can be used to reset the encoder to 0 between code executions.
Finish VI
The WPI_EncoderClose.vi is used to close the reference to the encoder.
Kelly_B
0 Comments
The Producer/Consumer design pattern is a great way to keep two processes in sync when they might run at different rates.  This is especially important when there is data transferred between the loops.  When programming your robot you can use the Producer/Consumer design to save data about motor speed, various voltages, accelerometer data, and a lot more!  This can come in handy as you're testing and fine-tuning your robot.
In this example the Producer loop acquires data from the LabVIEW Front Panel (the "Input Value" and "Scaling Factor" are Front Panel Controls) and adds it to a queue of data to be processed.  The Event Structure is where the data is actually added to the queue.  This part of the code runs when the number in "Input Value" changes (for more on Event Structures, see this blog post).  The Consumer loop then removes each element from the queue, displays it on the Front Panel ("Result Value"), and adds the data to a text file.  Because writing data to a text file is a time consuming activity, the Consumer loop takes longer to run than the Producer loop.
This White Paper talks about the Producer/Consumer pattern in more detail and has some additional example code snippets!
