LabVIEW Development Best Practices Blog
Community Browser
data export to a single excell sheet
Amit Mondal
Hi:
I am using labview to read intensity data from a camera. I have a constant X where Y is variable. SO i need only the Y data and it comes as one column.
Everytime when i export to a excel sheet i save as a new file.
What  I want.... to save all the data in a single XL sheet. If possible to do with a shortcut key would be great. In that case just press a key and data will be saved in a particlular file. If i press 10 times there will 10 different column in that file.
Anybody can give solution?
Thank you in advance
REgards,
Amit
Comments
