inversion
Abort all VIs Button in Taskbar (Modal Windows Problem)
Status: New
There are times when I leave a VI with modal properties open and then I run the main application that also calls this VI if opened in the development environment. This locks all running windows due to the modal VI. I propose a button in the taskbar that aborts all running VIs OR perhaps a list is opened on right-click of all running VIs 🙂
:. LV2010 SP1 ... W7 .:
23 Comments
oenk
Great idea...
In the meantime you could use the LAVA Abort VI.vi written by Jim Carmody
you may find it here on
LAVA
br,
\c
inversion
Sweet. Thanks!
Darren
Proven Zealot
This would be a good item to place in the LabVIEW jump list for Windows 7.
inversion
Yea I like that! Time for NI to move forward!
GregFreeman
Trusted Enthusiast
Thank you! This drives me nuts
SimonH
NI Employee (retired)
I read your post and thought "that's a good idea" and then I realized I have something like this functionality today:
Download this VI: http://decibel.ni.com/content/docs/DOC-2309
And then pin it to your LabVIEW icon in the taskbar like so:
Since this has a UI it doesn't help with modal windows (as you requested) so I rewrote another version to just abort all running VIs.  It's attached to the same document above.
So now I have:
For all my get out jail free needs.
inversion
Awesome work! I really like that... many thanks for your post
JÞB
Knight of NI
I usually have this function on my top-level (or any code I may "run" while having left a dratted modal FP open)  for just such a reason
"Should be" isn't "Is" -Jay
AristosQueue (NI)
Two points:
1) The abort tools posted above do not handle clones of reentrant VIs that are free running either because of the Run VI method or because of the Async Call By Reference "Fire and Forget" mode. Clones are not listed in the "all VIs in memory" list.
2) There's a second idea, not quite as many kudos, but perhaps just as useful, to put an abort button on the Project Window to abort the VIs for that project only: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Abort-All-VIs-in-Project/idi-p/1818849
I happen to like this one because it is scoped to the VIs I want to abort (typically) and because it would be available on non-Windows platforms.
Les__Bartel
Am I missing something? It sounds like this is a bug and NI just needs to fix it. My usual first reaction to "this must be a bug" is "I must not understand it". So, a GOOD explanation could justify this behavior.
