The current VISA read and write primatives do not have the ability to abort early. Under many circumstances if the timeout values are short this is not an issue but it can be an issue if a long timeout is required. The current work around is to use a short timeout value and loop continually ignoring the individual timeouts until a threshold has passed and then pass the timeout error out. This apporach requires the extra code to "monitor" the process of the communication. It also requires shift registers and associated logic to maintain the data. It would be desireable to simply set the timeout for the desired value and have a separate VISA property that can be set cause the current operation to abort.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
