PrimaryKey
Add custom commands extensible interface for QD
Status: New
Hello all!
The standard LabVIEW plugins are great but operate based on Ctrl + Key shortcut. This means that after a while almost all of your keybord keys can be occupied by a shortcut.
Please add an interface for defining commands in the QD ComboBox, which could be used as a more extensible option over single keys.
Example - a Dialog command could be invoked like this:
Ctrl+Space -> Dialog Text -> Ctrl + CCtrl+Space -> Dialog Text -> Ctrl + C
Example community package implementing this can be found here: https://forums.ni.com/t5/Quick-Drop-Enthusiasts/Class-QD-Plugin-Package/gpm-p/3992772
Thank you!
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
2 Comments
PrimaryKey
NI Employee (retired)
Additionally this idea should include the option to reuse the previously used Commands, like a command line interface. Also this QD configuration should allow to show the commands available. Alternatively QD configuration could include another tab for command definitions.
Piotr Kruczkowski
tst
Knight of NI Knight of NI
Knight of NI
Somewhat related idea, which suggests a different mechanism to do something similar - https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Supercharge-Quick-Drop-Turn-QD-keyboard-shortcuts-int...
Personally, I tend to use the context menu plugins more than QD shortcuts, and text based commands would probably not get me closer to using QD more. I suspect many users would have similar preferences, although many people also like text.
___________________
Try to take over the world!
