Darren
Add "Replace with For Loop/While Loop" methods to VI Scripting
Status: New
You can right-click on a While Loop and select "Replace with For Loop", and vice-versa:
Neither of these operations is currently available in VI Scripting. If they were, Quick Drop and other G-based editor features could benefit.
2 Comments
Darren
Proven Zealot
Interestingly, there is support in scripting for replacing Timed Loops and While Loops with each other.
Darin.K
Trusted Enthusiast
I have been doing this with the right-click framework since LV9.  I do not use the RCF any more but I tested the code in LV12 and it still works.  Adding the conditional terminals was easy, but the subdiagram labels are a bit of a trainwreck.  I'll have to hack around that.
Overall it was pretty easy to implement, about an hour (it would be less if I were the world's fastest LV programmer).
The native replacement would be nice, it is faster.  My scripting version breaks a ton of stuff and then fixes it, which I still enjoy watching in a weird sort of way.  There is that moment of anticipation when everything is broken, followed by relief.
But to be honest I do not support this idea as is.  I'd rather fix the native replacement to maintain wiring to the conditional terminals.  Then add the scripting support.
There is a comment in one of my VIs though: (edited for family viewing)
WHY THE F#$K IS THE LOOP COUNTER NOT INHERITED BY THE LOOP CLASS???!!!!
I was tired of casting to the specific loop type to get the reference.  The same could be said for the conditional terminal now that they all have one.  I would move it up the hierarchy and make it an error to write false to the While Loop HasCondTerm? property.  But I digress.
http://screencast.com/t/kmNIL4La
