viScience
Allow Selection of 'Late' Network binding for HMI controls and indicators
Status: Declined
Currently, if you want to programmatically bind HMI controls and indicators to network URL's you need to first set, at edit time, a fake
URL (example: \\192.168.0.3\cRIO-HPU\'PU.Accumulator_Dump_Valve') since the actual IP address may not be known at edit time.
If you leave the HMI 'unbinded' then the attempt to set the BindingPath properties will result in an error.
It would be nice if you had a generic option called 'late binding' that you could select with the expectation that the exact URL will be set
at runtime.  This would provide an additional benefit where the  PSP driver could wait for a BindingPath to be set before attempting
the first transaction.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
