usrfrnly
Allow Wire Labels to Dictate Name Inheritance in Bundles
Status: New
Not every bundle is linked to a Typedef. It would be very useful to automatically inherit the names of previously named wires into bundles.
Showing the Current and Proposed behavior for name inheritance in the bundle functionShowing the Current and Proposed behavior for name inheritance in the bundle function
13 Comments
raphschru
I think what you are proposing is more generally to be able to rename the data using the wire label.
While I think this is a good idea, I'm just exposing some particular cases.
How would you name the elements in the following cases:
usrfrnly
Wow, raphschru, thank you for those examples; they really highlight both the power and possible pitfalls. My opinion is the last label should take precedence (so "X", "Y", "Z", and ""This is just a comment" in your examples), but I could see how it might not be possible to implement changing labels on a single wire.
wiebe@CARYA
Knight of NI
I'm not sure if this is a good idea, and if it is if it will even happen, but...
Iff this gets implemented, it should be considered for variants too:
If this is going to be the way objects get their wire label, I think at least it should be consistent.
srlm
Wire labels are not names, in my opinion. Comments should not change code. If you want to name the items, do it formally with a Coerce To Type node. Or, you know, make a constant and wire the middle terminal of the bundle... 😉
drjdpowell
Trusted Enthusiast
Though I wouldn't use the wire labels, as they are used as documentation, I would really like a way to change the name of a wire, so as to be able to define clusters like this.
srlm
@drjdpowell This is a primary use of the Coerce To Type node. It allows you to set the name of the downstream wire.
drjdpowell
Trusted Enthusiast
"Coerce To Type" coerces the type, hence the name.  It changes name as well, but I usually don't want to coerce the type.
srlm
A change in name is a change in type. It is nonsensical to say that you want to rename the type without changing the type because the name is part of the type. You wire the identical data structure into the center as into the left but with a different name.
drjdpowell
Trusted Enthusiast
An example:
Imagine an output of a subVI that is a SGL named "Process Variable".  You rename using Coerce to Type to be named "Temperature". Later, someone upgrades the subVI to use DBL, but no-one remembers to change the SGL constant.  Now you are losing precision without realising it, coercing a DBL to single precision.  A bug.  At best, you'll waste time running through all your code hunting for coercion dots.
srlm
If that's an actual concern for you, there's a solution for it:
If anyone tries monkeying with the representation, the VI breaks.
[Ignore my comment about .vim... I forgot about the terminal names overriding on VIMs.]
