EthanStern
Allow changing numeric conversion type with selector tool
Status: Completed
Available in LabVIEW 2019 and later. Right-click on one or more conversion bullets and select a new bullet type from the 'Replace Conversion' submenu.
Browsing through menus to replace a numeric conversion node is tedious.  How about allowing the selector tool to select from a pull-down menu, just like it does from an unbundle by name node?
Existing unbundle node behavior is shown at left.  Desired numeric conversion node behavior is to the right.
16 Comments
altenbach
Knight of NI
related idea ( your seems like a duplicate of it?)
EthanStern
Yes, thanks.  It appears this idea already has some momentum.  My post is redundant with regard to yours: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/A-universal-conversion-bullet/idi-p/918414
 (...and I like your post name better)
PaulG.
Leave this idea here. Altenbach's idea has over 100 kudos but it's over 3 years old. Might have lost some momentum. This is  something I've wanted for a long time, BTW.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
coldy_robsten
... and make the conversion behavior consistent, BTW.
I mean it's illogical to keep the output typedef'd if the base type of an typedef's input is the same as the selected conversion function...
Manzolli
It's so obvious that I kudoed both altenbach's and this one.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
Jim_Glanz
I would vote for this, excellent idea!
crossrulz
Knight of NI
Jim_Glanz, then what's stopping you from giving the idea a Kudos?  A comment saying "good idea" will not give NI any idea of how desirable the idea is.  That what the Kudos are for.  So if you like the idea, give it a Kudos.
GCentral
Silver_Shaper
Awesome idea. Hope going to be there in LV 2013
Silver_Shaper | CLD
jfleming
Maybe in 2014.  This is a neat idea.
LabVIEW Champion
Certified LabVIEW Architect
AristosQueue (NI)
NI Employee (retired)
> Maybe in 2014.
Nope. If it were, it would be marked "In Development" or "In Beta" by now.
