When debugging labview application. If we use lot many probes at a time then it becomes to complicated to understand which probe is which one.
The main reason for confusion is probes are named by probe number and its data type.
Also when I manually name the probe it should update the label.text property of the wire
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
