P@Anand
Drag and Drop teminals for Easy terminal assignment
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
In connector pane we have the option of switching the connector pane by Pressing Ctrl and click but it would be very nice to have an option of Draging a connected to other location may be implemented by
1. Press Ctrl + Shift  so the mouse pointer change to Normal arrow
2. Click on a terminal and drag it to the new location.
Its pretty handy comparing to the swap terminals.
4 Comments
RavensFan
Knight of NI
I don't see how this is a benefit over what we have now.  If anything, you are adding another key press.
stbe
If you want to move a connected terminal to a free position, you can already do that, because the switchero-tool [Ctrl] on the connector pane works for all terminals (not only the connected ones ...)
-Benjamin
_________________________
CLA
r_exler
Why not allow to drag and drop without using CTRL key if the destination position is unused?
Darren
Proven Zealot
Status changed to: Declined
