Why is "Rearrange Cases" not an option for a Case Structure with two cases? This page (http://zone.ni.com/reference/en-XX/help/371361H-01/lvdialog/rearrange_cases_dialog_box/) indicates that you need at least three cases in order to summon the Rearrage Cases dialog box. What if you just want to swap the order of two cases (For example: so that the default case is first or last). Currently, I have to add a dummy case, rearrange, and then delete the dummy case.
