Sometimes opening one or more projects, s.b. can still loose the overview over all opened windows and VIs.
Unfortunately if you run your project and then finish it, labview will automatically add the newest window on the right side of the task bar.
This will cause a lot of searching and clicking through all opened windows because there's no chance to see if a file is dependend on project a or b.
It'd be great if there's an option allowing labview to automatically reorder the task bar program shortcuts as you may find in the attachment.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
