User | Kudos |
4 | |
2 | |
1 | |
1 | |
1 |
When adding a control as a cluster constant it's important to see what's the controls name in order to use the constant correcty.
As you can see on the right side of the image there's how a control will be added when you drag&drop it into the block diagram.
To show every label it's quite a lot of work to click on each single item (it's hard enough to hit the control correctly!) open the contect menu and select "Description" to show up.
It'd be a great relief, if you can simply select "Show all labels" to perform the same operation with 3 but 20 clicks.
Also there should be a function to automatically select if the text should be upper, lower, left or right to the constant.
