Andrey_Dmitriev
Allow simple arithmetical operations on Numerics like embedded Formula String
Status: New
Many of us using graphical programming for scientific applications, where we dealing with numbers, measurements, etc.
How often we grab to Windows Calculator to compute simple equations?
What about ability to enter something like 3,75*2,8 into any constant or control (in principle everywhere where we can put numbers) and then get computation result in this place:
In the past I've worked in desktop publishing industry and using the software called "Macromedia Freehand MX", and that was really "killer feature", which saves huge amount of time.
This is how it works:
Or for example, 5 rotated copies:
Even in Color mixer simple computations are allowed:
Everywhere where I can put some numbers, in any dialog:
So, my suggestion to have the same in every numeric control or constant.
This is what I mean:
So, it should be allowed to enter here something like "3*5" or "42+3*5"
As MVP suggested to have the only (at least) base operations *, /, +, -, also combined as shown above, but may be "advanced" support (like fully offered by Formula String) is also not so bad, why not:
Anyway it should work everywhere, including constants on the Block Diagrams:
Also, for example, on Resize Objects Dialog:
Or even in the Settings (in general everywhere for any numeric field across whole LabVIEW):
And also in Run-Time, of course, not only in Development Environment.
If you think that "always enabled" feature will be annoying, then I can suggest to make this optionally per Control/Constant Option:
Or may be as global setting in the Options.
5 Comments
crossrulz
Knight of NI
Duplicate: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enter-Equation-In-Numeric/idi-p/1681978
GCentral
Andrey_Dmitriev
Trusted Enthusiast
Thank you, haven't seen this, now kudoed. Well, my proposal a little bit more "generic" and propagated also to any numeric (also in every dialog), but as far as I can see - this obvious Idea is 13 years old and still not implemented, so will stay with my self-made solution. It is a really convenient to have this feature "out of the box".
crossrulz
Knight of NI
>Thank you, haven't seen this...
Yes you have.  Look at the last comment (from 2016).
GCentral
Andrey_Dmitriev
Trusted Enthusiast
😂 Oh, no, no, no, I'm too old... Really forgot about this. But now remember, yes, already have seen.
Mads
A nice advertisement for an old but not yet implemented idea 😊
