User | Kudos |
12 | |
6 | |
5 | |
5 | |
4 |
As in the subject.
Now when you create an array the indexes of the array can be only labeled as the static comment field. There is not any build-in label/handler which could be used. Current situation looks like that:
It would be better for readibility if developers could name the indexes and use it later on.
Picture represents the idea only, whole point is the description shoud be a build in handlers.
Now LV names first four indexes (when you hover over on it) as column, row, page, vol; later on are only dim 5, dim 6 and so on.
I believe if would increase readibility and save coding and debugging time.
