When you use the autopopulate view in Labview project you have a direct view on the OS directories.
You are able to add new elements, rename elements ... but not to delete them !
It should be nice to add the ability to delete an items from the autopopulating view, using the "Context sensitive menu".
I also noticed that it is impossible to add/remove new folders ... you have to open a file browser to manipulate folder ...
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
