lvrat
Auto Connect error to terminal
Status: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Front panel has error in and error out terminals.
To provide a right click option on connecter pane to "auto connect errors". This would connect the errors to lower right and left terminals automatically.
If only error in is present then 'auto connect errors" will only connect lower right terminal.
CLD
3 Comments
garrettmarsh
Did you mean 'error out', if only lower right terminal is connected?
lvrat
@garrettmarsh , nice catch I seem to say lower right terminal instead of lower left terminal. To word it correctly it will be "If only error in is present then 'auto connect errors" will only connect lower left terminal." and likewise if only error out is present then 'auto connect errors" will only connect lower right terminal.
CLD
Darren
Proven Zealot
Status changed to: Declined
