I would always like to see an Auto Optimization Tool (AOT), that will actually suggests and corrects not just Rube Goldberg Code but also unnecessary/unused codes. I understand, based on continuous advancements in the LabVIEW compiler, compiled code generated from the VI are optimized to great extent... but we like to see if in the source code itself, some sort of optimization can be done so that a developer (specially learners like me) also gets to know that, in what different ways code can be optimize or what section of their code can be removed without affecting the functionality.
Now after I select AOT, similar to BDCT, it should make the code optimized. There should also be an available option, just to list, wherever this tool feels correction is required and let developer to take a call whether modify it or leave as it is.
Few examples what AOT should be capable of:
1. Remove Coercion Dots:
2. Remove Unnecessary Constants:
3. Remove Unnecessary Code:
well there is no end of types of 'unnecessary codes'...
Any other suggestion you want to add, is most welcome...
