Current behavior:
When configuring a type specifier for Open VI Reference so I can run Start Asynchronous Call, I drag a VI onto a type specifier VI Refnum.
If the pinout of that VI changes at all - even if the only change is to add an item to an enum - the call to Start Asynchronous Call breaks, because the types no longer match.
Desired behavior:
When configuring a type specifier (constant, control or indicator), I can maintain the link to the source VI, so if the pinout of that VI changes in any way, the type specifier doesn't have to be manually modified. In essence, I want an "Auto-update from type definition" option for type specifiers, with the VI as the type definition.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
