Hi
Often when I implement a .vi I start by implementing the main functionality, and there after handles error scenarios such as timeouts, overflow etc. Between implementing the main functionality and the error handling I write a 'todo' text so I remember to handle it later on. Wouldn't the world be a better place if I could have a window open that would list all these 'todo' items nicely sorted by Folder/.vi and when clicked on and item you would be brought right to the spot?
Here is an example of a C# project from VS2010 using ReSharper:
The window should simply search for text occurrences of the words 'todo', 'bug' and 'not implemented' etc. This is a nice tool I use a lot in VS2010 and it would be really nice to have similar functionality in LabVIEW so I won't have to do manual searches all the time, which by the way does not give the same overview as a separate auto-updating window would.
