The conditional disable structure gives the developer to create multi-function applications. However, right now in order to build these applications into different executables the developer must go in and change the project conditional symbols and then re-build the applications and hopefully remember what the symbol states were when the application was built. It would be great if during the application build process the conditional symbols could be set. This would allow the developer to create multiple build specs for each different implementation of the application. An example is shown below:
