Looking at code of others, it is sometimes difficult to tell what kind of control or indicator we have, especially since some can be made to look quite similar, even though their function is quite different.
Example: If there is a graph and the label has been changed, it is not easy to find out if it is a waveform chart, a waveform graph, or an xy graph.
To figure it out, we have a couple of options, and none are very intuitive:
Suggestion:
Maybe always, but at least whenever there is no custom description (i.e. cases where the context help shows "no description available"), it should also give the generic name of the object, the way it was called in the palette.
For example if I drop a string from the system palette, the label is simply "string" but the context help should show "system string" in the second line: the tag it had in the palette.
Of course customized controls should indicate that fact too somehow.
Similar labeling should also apply to cluster elements.
