Unless the programmers is pretty familiar with LabVIEW, debugging can be confusing, for example if uninitialized shift registers and feedback nodes retain data. Suddenly the results are different between different runs with the same setting.
One might innocently expect that if I do "menu...edit...reinitialize values to defaults", I start again with a clean slate, which is of course not true if there are USRs. There is hidden extra data lurking beneath the surface.
I remember that this confused me when I first started with LabVIEW 4.0 many years ago. There is currently no direct way to "reset" a VI to the way it was right after loading (all controls at the defauls, all USRs cleared, etc). The only way to clear USRs is with a "file...revert", which has the unwelcome side effect that we lose all edits, meaning we need to constantly save versions to keep up.
I would prefer if there was a menu to clear all internal data structures from a VI without having to save the VI first. Alternatively, maybe this action should be included automatically if we reinitialize a Vi to defaults.
