User | Kudos |
5 | |
2 | |
2 | |
1 | |
1 |
Hi.
I'll propose a more informative set of tooltips for shift registers. Especially when you drag out shift registers to access older values as well, I always have a difficult time remembering which is the most current value, and which is the oldest (is it the one on top, or is it the one at the bottom...).
Currently all shift registers have the same tooltip, namely "Shift Register". I suggest to change that into an indexed iterator variable name:
Cheers,
Steen
