GregFreeman
Build specs should NOT silently remove items if they are deleted on disk
Status: New
I currently have a project with an auto-populating folder for documentation. That documentation is included in my Installer build specification.
If I regenerate that documentation while the project is open, the auto-populating folder sees it disappear from disk and removes it from my installer! No notification, nothing. Just completely silent. This has resulted in shipped installers with missing documentation
I propose this should work the same way any other dependency does if it disappears from disk. It should break the installer from building and show a warning sign that the dependency is missing.
4 Comments
wiebe@CARYA
Knight of NI
Same for re-building a dll (if it's not locked).
+1
raphschru
What if you add the folder itself (instead of each file) to the installer, then regenerate the content of the folder?
Otherwise if you don't want this behavior on a single-file dependency, put it inside a virtual folder instead of an auto-populated one. In case this file is missing, the project explorer itself will show a missing file warning.
I think the behavior you observe is consistent with the philosophy behind the auto-populated folder. Since it auto-populates, then it should also "auto-depopulate" 😁.
wiebe@CARYA
Knight of NI
But it should follow the behavior of files. If you remove a file from a library or class, you get 'missing file'. That is what you'd expect in ta build specification.
I haven't tested adding a folder, but I have a recollection (that might be wrong) that adding a folder will only add the files in the folder once. If files are added, you have to add the folder again (or the added file). But that's only how I remember it.
thadyale
I do think if you explicitly include a file from an auto-populating folder, it should at least attempt to find that file at build time instead of simply vanishing during the moment where the file is replaced.
But in the meantime, I recommend simply including an entire autopopulating folder in your build, if possible.  I do that in my RT packages and it works great, even with files that get regenerated during the application build process.
