Whenever I use a DVR with the inplace element structure - particularly if I unwrap data which is then actioned by a subVI or function which has error terminals - I have to use a merge error function to make sure any errors reach the error handler. Could we have error in terminals on these functions - in the image below I'd like the two pieces of code to have similar functionality!
This is also the case with the variant in/out border node. In that case both sides of the node have error outs while in regular code the convert to variant has no error terminals and the convert from variant has an input and an output!
My preference would be that the border functions would be exposed to errors on the error wires. However maybe there is a good reason this feature is missing due to the inplace functionality. If so perhaps we could get an implementation that is cosmetically identical to the lower drawing but programatically identical to the upper implementation (aside from the bounding case structure). Essentially the border nodes would all include a 'merge error function' instead of being exposed to the error input outright.
DeltaJ
