P@Anand
Cleanup Diagram with Option
Status: New
Excuse me if it has been already proposed.
In many cases I don't use the Cleanup diagram feature instead I would clean the code manually. In those cases its time taking to check for the bend wires so it would be good to have an option along with the cleanup diagram feature to have only to remove the broken wires, Clean up the bend wires like that. If the VI doesn't have a Breakpoint for example that can be disabled and whatever applicable can be enabled. Here is what I propose
I guess this can be extended with other usefull options also.
3 Comments
Darren
Proven Zealot
This is what got my kudo...I'd want to provide my own scripting VIs that could plug-in to this menu option.
altenbach
Knight of NI
Well, we already have the "right-click...clean up wire" as well as selective diagram cleanup (select the wire(s) and press the cleanup button) with the same effect.
I agree that it would be logical and functional to have these tools (remove breakpoints, remove broken wires, etc.)  as part of the cleanup tool button. So kudos!
JackDunaway
Trusted Enthusiast
Agreed with Darren on end-user extendability!! +1
