Sometimes when you hit the Cleanup button in a block diagram it doesn't work. There seem to be many reasons, complexity of the block diagram, certain objects make it fail, etc. This idea is not how to fix those failures, but when they do occur, the cleanup routine should give some response back to the user. A dialog explaining what is wrong, should be shown.
Currently if you hit cleanup and it is going to work, you get the spinning blue circle and it cleans up. If it doesn't you get NOTHING. As if your click wasn't registered. There should be some response.
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
