Rindert_Nauta
Compiler optimalisation options to get rid of the long compile times
Status: Completed
See this KnowledgeBase entry regarding the compiler setting for this issue: http://digital.ni.com/public.nsf/allkb/3A28C7098620AFD78625783400763C69
I would like to have some kind of compiler optimalisation options.
The save time is often to long, Editing is annoying
Editing in LV2010 often halts for 10-20 seconds because it it recompiling the code for some reason.
If we had some option to turn off "advanced optimalisation" things might go fluently, like in the old days.
6 Comments
elset191
Sounds the same as this
Tim Elsey
Certified LabVIEW Architect
AristosQueue (NI)
NI Employee (retired)
LV 2010 SP1 will address this performance hit.
Rindert_Nauta
It is not the same as Postponing.
I want to get rid of this optimalisation if I do not need it.
Then saving and running (testing) could always be fast.
A lot of compilers have options to set the amount of optimalisation you want (or need).
Edjsch
I agree with Rindert. By NI's own admission, compile times can be 5x as long! It may not be easy to do, but it would be great if there were a compiler switch to go back to pre-LabVIEW 2010 compiler performance. The user could then uncheck this option when he/she is ready to build.
Craig_
Relevant KB: http://digital.ni.com/public.nsf/allkb/3A28C7098620AFD78625783400763C69?OpenDocument
There's a compiler setting for this now!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Darren
Proven Zealot
Status changed to: Completed
