LukeASomers
Contextual menu's Find submenu on controls should include event handlers
If you bring up the contextual menu on a control, you can go to the Find menu item and search for things related to that item. Like, if there is at least one local variable, you can find local variables for that control by picking Local Variables.
This also works for finding the control's presence on the other side (front panel vs back panel), and Property Nodes and References and perhaps some other things. But, it doesn't let you find event handlers for that control.
It woud be very nice to be able to find the control's event handlers through this submenu.
7 Comments
X.
Trusted Enthusiast
Trusted Enthusiast
https://decibel.ni.com/content/docs/DOC-43206
Close enough?
That's what I now use to do what you are asking for (which I don't think is a new idea, but I may be wrong).
tst
Knight of NI Knight of NI
Knight of NI
X., I assume you meant this one - https://decibel.ni.com/content/docs/DOC-43240
___________________
Try to take over the world!
X.
Trusted Enthusiast
Trusted Enthusiast
Actually, I was not aware of this one. The one I pointed at allows accessing the event cases by attempting to create them. If they already exist, you are sent to them. That is of course not as direct as the one you are pointing at.
LukeASomers
Yes, that would do nicely.
elset191
Definitely not a new idea.  There are at least 3 others that link to this one.
Tim Elsey
Certified LabVIEW Architect
LukeASomers
Quite - I don't know why my search for previous suggestions came up empty. Maybe I was searching in the wrong subforum by mistake.
Darren
Proven Zealot
