Daklu
Copy path in project explorer
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
I really like the "Display Path" option in the project explorer window and always leave it enabled.  However, in order to copy and paste the path to a block diagram I have to...
Right click > Explore...
In Windows Explorer, shift right click on the vi > Copy as path
Close Windows Explorer
In Labview, paste path in path constant
Edit the path to delete beginning and ending quotes
It would be much easier if I could just select the path in the project explorer Item view, hit Ctl-c, and have Labview copy the unquoted path to the clipboard.
4 Comments
tst
Knight of NI Knight of NI
Knight of NI
Alternatives:
  1. Drag the VI into a path constant (either from the project or from a BD).
  2. Right click the VI and get its path from the properties dialog.
  3. If you need a VI's path, use a static VI reference and get the path property (what I do, because it protects you from changes and automatically handles the VI when building an app).
___________________
Try to take over the world!
Daklu
"If you need a VI's path, use a static VI reference and get the path property (what I do, because it protects you from changes and automatically handles the VI when building an app)."
That is what I do for real apps for exactly that reason.  I use copy and paste for things like testing a component with a path as an input.
"Drag the VI into a path constant (either from the project or from a BD)."
Perfect!  Better yet, it works for non-vi/ctl project items--like config files.  I know LV does lots of handy things with drag and drop, but this didn't occur to me.
Request withdrawn.
tst
Knight of NI
You can also drag from Windows Explorer into a file constant (or control. You can use a large transparent path control with a value change or drag end event to open files which the user drags into your target).
___________________
Darren
Proven Zealot
Status changed to: Declined
