P@Anand
Create Delimiter for Write to Spreadsheet - Clean up required
Status: New
In Write to Spreadsheet File.vi when we try to create control for the Delimiter, the control gets overlayed over the VI itself. The same is not happening in the case of Read from Spreadsheet.vi file, so this need attention. Please ignore if it is already suggested.
5 Comments
PaulG.
I don't see the behavior LV2013.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
P@Anand
Trusted Enthusiast
It happens with LabVIEW 2012. When I checked in 2014 its not happening but the Control is getting placed at the top which is supposed to be at the bottom as it creates for the Read from Spreadsheet file.vi.  So in any case a cleanup is required.
PaulG.
I see your point. Agreed.
PaulG.
parthabe
Trusted Enthusiast
Not only this, there are quite other functions that show this kind of behaviour.
- Partha ( CLD until Oct 2024 🙂 )
P@Anand
Trusted Enthusiast
Yes. I was have already proposed few. You can check this for an example. 🙂
