When you are viewing a block diagram of a VI you can ctrl+double click a subVI to open that subVI's block diagram directly (instead of having to open its front panel and then switch to the block diagram). It would be nice to be able to do that from the project window as well. Ctrl+double clicking or ctrl+enter on a VI in a project window should open the VI and immediately switch to the block diagram.
