DanyAllard
Be able to customize two control at the same time
Status: Declined
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
When you select "Advanced->Customize..." on a control you can't Select a second control and do the same.
This way it's a pain to "copy past" image from one to the other control. It should be possible to customize two controls at a time
LabVIEW ChampionArchitect
3 Comments
Matthew_Kelton
You can customize two controls at one time, they just cannot be in the same VI.  I'm not usre NI has ever given an (accepted) adequate reason for not allowing editing of two controls in the same VI.  This has been dicussed in the LabVIEW forums.
tst
Knight of NI Knight of NI
Knight of NI
This was already suggested here. AQ gave an explanation there, but I can't say it was really accepted.
___________________
Try to take over the world!
Darren
Proven Zealot
Status changed to: Declined
