10Things_Rob
Disable Diagram Zoom
Status: New
I may want to use it 0-5% of the time.
However, I want to scroll through cases in a structure 95% of the time.
Making the 5% use case the default (ctrl-scroll) was a bad design choice.
Reverse it before it's ingrained.
(ctrl-shift-scroll is frankly awkward and imagine will become painful eventually)
9 Comments
crossrulz
Knight of NI
Ctrl+Scroll is an industry standard for zoom.  So, I do not fault NI for making this decision.
GCentral
Dataflow_G
Having zoom operate with ctrl+shift+scroll would mirror the current ctrl+shift+click to pan behavior. So holding ctrl+shift would allow pan and zoom without needing to switch modifier keys. For that reason I like the idea of ctrl+shift+scroll (plus years of ctrl+scroll muscle memory for switching cases).
wiebe@CARYA
Knight of NI
CTRL+b clears broken wires, except when text is selected. Then CTRL+b makes the text bold.
Why not have CTRL+mouse wheel zoom, except when the mouse is in a multi frame structure?
The BD would 'catch' the event, and if nothing handles the event, it's passed to the VI.
Like CTRL+b, CTRL+i, CTRL+u...
Kirk
Or you can give us an option to edit these keyboard shortcuts in the options dialog.  We could choose to use CTRL-Scroll to zoom or swap cases in structures.
JensG69
I agree, give us an ini key with which we can select what happens on Ctrl-Mousewheel.
Kudos are welcome...
parthacg
KNIGHT OF NI
If that is the case, Ctrl+LeftClick is the industry standard (esp in Windows) for multiselect; but why did/does NI provide Shift+LeftClick for multiselect?! 😀
wiebe@CARYA
Knight of NI
FYI (don't know why this isn't public):
Editor.Zoom.BlockDiagram.MinFactor=2
Editor.Zoom.BlockDiagram.MaxFactor=1
Editor.Zoom.BlockDiagram.Enabled=False
To set the min, max zoom factor, or to disable zooming.
Disabling zooming does bring back scrolling through cases.
I can see advantage in a MaxFactor of 1. I always advocated for a zoom >=1, to prevent 5 screen wide monolithic VIs.
A min and a max allows for a more liberate scroll wheel action: the zooming is clipped, so you can scroll all you want and get the same zoom factor.
crossrulz
Knight of NI
parthacg,
Ctrl+Click and Shift+Click are standards for selecting in many Microsoft applications, including Visual Studio and Visio.
GCentral
wiebe@CARYA
Knight of NI
Editor.Zoom.MouseWheelGestureRequireShift = True
Now we have the original gestures, and zoom gestures when shift is pressed.
Exactly what people been asking for..?
