Sometimes you could have a "T" and a "F" and if you align them on top of each other and you wire it to an indicator, sometimes it can be very misleading in large programs.
Somehow if constants can "repel" each other, then we wouldn't have this problem. Attached is a small example where the "T" is hidden behind the "F" and so the indicator shows "T" even though visually it looks like wired to "F".
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
