User | Kudos |
9 | |
2 | |
2 | |
2 | |
1 |
When you feed the 'TDMS write' primitive with a string array containing duplicate channel names, you will get one row of data (when 'interleaved' mode is chosen) , regardless how often you write new data.
It took me really a long time to debug: the string array containing the channel names another developer provided was partly hidden.
The help does not warn you for this and no error or warning is thrown.
Somehow you should be warned and/or LabVIEW should add a sequence number.
Moved to CAR Database: CAR 641269.
